Sinkki-Ilmapatteri
Sinkki-Ilmapatteri
ViestiKirjoittaja jussik5 » 04.11.2009 20:07
Morjesta
Mielenkiintoinen keskustelusäie ruotsalaisella saitilla.
http://elbil.forum24.se/elbil-about844-0-asc-0.html
Eiks meitillä oo ruatti niinku toinen ... (siis kaikki osaa) ;)
Zinc-Air battery DIY 1,4 V 100Ah.
http://www.youtube.com/watch?v=s35sJwX1jlo
Re: Sinkki-Ilmapatteri
ViestiKirjoittaja mikar » 04.11.2009 21:38
Sinkki, ja kaiketi ilman happi siellä tärkeää.
Jotakin etuja ja kohtia, joita kaiketi voidaan saada parannettua
http://www.mpoweruk.com/zinc_air.htm
Advantages
High energy density but low power
Inexpensive materials
The zinc-air system, when sealed, has excellent shelf life, with a self-discharge rate of only 2 percent per year.
In relation to their physical size, Zinc/Air batteries store more energy per unit of weight (in terms of 220 Wh/kg) than almost any other primary type.
Primary cells available in a range of button and coin cell sizes.
Rechargeable high power cells available for traction applications.
Shortcomings
Sensitive to extreme temperature and humid conditions.
Carbon dioxide from the air forms carbonate which reduces conductivity.
High self discharge.
After activation, chemicals tend to dry out and the batteries have to be used quickly.
Although recharging is possible it is also inconvenient and is only suitable for high power types.
High internal resistance which means zinc air batteries must be huge to satisfy high current needs.
High power batteries such as those designed for traction applications use mechanical charging in which discharged zinc cartridges are replaced by fresh zinc cartridges. The used cartridges are subsequently recycled.
ViestiKirjoittaja mikar » 05.11.2009 01:05
Mietin sinkki-ilma - patterin ja ultrakondensaattorin eroja. Oliskos tietynlainen akun ja kondensaattorin hybridi tulossa ja tullut.
Esim. http://www.tekniikkatalous.fi/incoming/article27575.ece
"Eestorin electrical energy storage unit eli eesu pyrkii väistämään ultrakondensaattoreiden pahimmat sudenkuopat. Yhtiö on kehittänyt keraamisen ultrakondensaattorin, jossa eristeenä toimii bariumtitanaatti."
ViestiKirjoittaja jussik5 » 08.11.2009 12:08
Eestorista ei ole kuulunut juuri mitään omistajanvaihdoksen ja Locheed-Martinin tultua
kuvioihin mukaan.
Ilmeisesti heillä oli suuria vaikeuksia katodin oksidaation suhteen.
Toteutuessaan Eesu olis kyllä aika mahtava superkonkka.
Tuolla historiaa ja tietoa http://peswiki.com/index.php/Directory:EEStor
