ViestiKirjoittaja siviili2003 » 13.02.2021 23:49
mitä mitä tapahtuu planeetallamme just nyt?
ViestiKirjoittaja mika_r » 15.04.2021 19:47
mikäs on kuvassa
mika_r
ViestiKirjoittaja siviili2003 » 13.05.2021 21:06
Näyttäs olevan dynamiitti panostus ja sähkönalli.
mutta mikäs kuvassa:
https://www.picuki.com/tag/MarkComings
786Mhz joku sanoo taajuudeksi
Joillakin muilla taajuuksilla saa näköjään ihmeitä aikaan, mm kvartsiputkessa vettä:
A recent (1965) possible verification of the frequency Keely used to dissociate water into etheric force was related to me by a scientist when we were discussing certain aspects of free energy. He wishes to remain anonymous for obvious reasons, but his name is on file. I have no other verification of this experiment, however I believe it merits telling.
The scientist, I shall call him Dr. X, was doing experiments with ultrasonic sound in a column of water. The object of the experiments was to devise a means of separating various densities of materials by injecting them into a column of water which was subjected to an ultrasonic standing wave vibration. The experimental setup is sketched in Figure 3-3 (for BBS considerations a description follows).
A Barium Titanate ultrasonic transducer was fixed to the bottom of a quartz tube which was closed at the bottom and open at the top. Pure water was poured into the tube and the water column was "tuned" so that a standing wave was produced at 40,000 CPS (cycles per second). The transducer was powered by a 700 Watt power amplifier which was driven by an ultrasonic frequency generator. Because of the large amount of power put into the column of water a certain amount of evaporation took place at a constant rate when the transducer was energized. Therefore, to maintain a standing wave in the water column a feedback device caused the frequency to be raised as the water evaporated and the temperature changed.
As a test, Dr. X decided to run through the experiment with only water in the tube to insure that a standing wave was maintained as the water evaporated and the frequency rose higher and higher. When the experiment was started everything worked beautifully. Dr. X took periodic readings of his instrumentation and was assured that the standing wave was being maintained. Suddenly, with no warning whatever the water disappeared from the open quartz tube. He looked up thinking to see the water splashed on the ceiling when to his amazement a clean hole went right through the ceiling. The hole was the same size as the inside of the quartz tube. Further investigation showed the hole continued on through the roof also! Dr. X checked his notebook and found the last frequency entry to be 41,300 CPS. It was shortly after this that the water disappeared. Because of the time interval between the last reading and the disappearing water, the frequency sent to the transducer was higher than the last reading and Dr. X said it could well have been very close to 42,800 CPS, the Keely dissociation frequency.
ViestiKirjoittaja tesla » 20.05.2021 05:08
Melkein sama luku pamahti mieleeni mutta... Se olikin 1000 kertainen!
https://www.quora.com/What-is-the-maxim ... transistor
Daniel Fishman Senior tech leader at Intel 798 GHz transistor.png (178.63 KiB) Katsottu 4389 kertaa
ViestiKirjoittaja tesla » 24.05.2021 00:31
Saunan uunin pesästä tuli nauloja paljonkin. Sitten kun kaadettiin tuhkaiseen sankoon vettä oikein kunnolla
tuli nauloihin kummaa väriä. mikä on tämä punertava , burgundinmainen väri? Entäs ruuvin päässä
olevat kellertävät pilkut?
Aikamoinen terratransformer tuo saunan hehkutin!
Sompasaunan uunin naulat ja ruuvit punertava aine.jpg (92.35 KiB) Katsottu 4381 kertaa
ViestiKirjoittaja siviili2003 » 24.05.2021 21:24
Kun sinkki oksidoituu se muuttuu kellertäväksi pölyksi.
punainen on sitä samaa rautaa mitä ihmisen veressäkin on.
ViestiKirjoittaja tesla » 25.05.2021 04:10
Kiittää ja kumartaa - toiset ne tietää
ViestiKirjoittaja Nelikulma » 08.06.2021 01:00
Mitä kuvassa? Helpotetaan sen verran, että kyseessä ei ole elektronimikroskooppikuva virusrokoteneulasta.
Taustaa:
Matala omakotitalo. Välikaton päällä matalaa, ahdasta ja jotain 30cm selluvillaa. Pitäisi saada datajohto pisteestä A pisteeseen B. Välimatka 12m. Kummassakin päässä luukku, mutta ryömiminen ei onnistu.
Ongelman ja kuva-arvoituksen ratkaisu:
Työnnetään selluvillan päälle 20mm sähköputki, jonka sisällä valmiiksi vetolanka. Putken päähän on teipattu muovipullosta modifioitu ”kartiokelkka” , joka ”pysyy pinnalla”, ja jolla putkea pyöräyttämällä pystyy hiukan ohjaamaankin. (takakartio siksi, että saa helposti vedettyä takaisin, jos alkaa tökkimään.)
P.S. Vedin johtoni putkeen, vaikka olisi sen putkella voinut vetää vapaasti villojenkin päälle.
ViestiKirjoittaja tesla » 03.07.2021 02:45
Mikä mineraali voisi olla kyseessä kyselee eräs joogaaja joka tekee nettikauppaa
Kemppainen Pauliina mika mineraali voisi olla kyseessa vapaanergia mini.jpg (22.6 KiB) Katsottu 4312 kertaa
ViestiKirjoittaja siviili2003 » 30.08.2021 22:13
löytypä outo kapistus, mikähän tämäkin on?
kun katsoo sisälle putkeen, auringonvaloo kohti, pikku kiikarissa on perillä mitta-asteikko
putkilon reunassa teksti: STEPHEN 272172
